da94broncodude
Well i finally got around to getting some tunes for my injectors/turbo combo and towing with it.
First off i can definitely see why 155s are recommended for the powermax if your gonna tow, i have a fs2600 weekend warrior toy hauler, i would say around 12k loaded up, theres a pretty steep grade on the way to our local sand dunes where i did my initial testing.
Truck Definitely has more power as it takes less to get the load moving and less pedal to hold speed, if i keep it from upshifting to the next gear i can move at a steady speed 55-65 no problem but if i let out at all it wants to shift and boost drops egts climb, the age old story. egts would cruise in the lower gear around 1200-1300 with tons of pedal left and if you chose to use it would go like hell but the egt gauge would peg.. so can you tow with 175/75s and a powermax? yeah but you really gotta watch the gauge and it really gets annoying.
Second towing adventure was a much steeper grade and i was towing my buddys 99 ECLB 7.3 on 37s and his Tahiti jet boat, we believe his hpop went out. on this adventure i seemed to have the same problem borderline egts i constantly had to make sure it was in the right gear and watch my gauge like a hawk.
So by all this i dont like the amount of heat and want to add some more air, i was thinking either batmowheel or having rcd make it a 68 or MTW turbo. ultimately the goal is towing with my 175/75s, what do you guys think?
