ic pipe and elbow
Dzchey21
wyoming
no limit ic pipe is the way to go
bigrpowr
<How I Fly
Administrator
The flo pro is a much shorter elbow with a much tighter radius entering the manifold. The pic is just an example bend of the no limit vs the shorter dd pipe.
UPINSMOKE
Dundalk, Maryland
The weld on it doesn't look as good as the flo-pro though. And some of the pictures it shows that the pipes aren't even lining up perfectly. For how much they cost I'd expect perfection.
Sent from my iPhone that is fueled by haters
bigrpowr
<How I Fly
Administrator
Flo pro / dd is welded by a machine in china. Mine is welded by an American person.
P.S. the design I did makes for lining up to be more of a challenge , most of the time it's massaging, but occasionally they don't line up perfect. Anytime that has happened I send out a new pipe same day. Sorry it's not perfect enough, but its a better option than most at this time. In that pic, the bend I compared it too is aluminum, or you couldn't already tell? The welds are different.
Powerstroked162
On Da Juice
Wa. State
The No Limit piece is nice. Best I've seen so far, and that's not a biased opinion. I don't see many complaining about it either. Can't beat form and function...
