ICP pressure
Extended Power
Just wondering what we should be seeing for ICP pressure at idle, 1000, 1500, 2000, 2500, etc etc.
I know that if we don't have 4000 psi at 4000 rpm, we aren't making the power we could be...so is it 1000 psi per 1000 rpm?
faster6.0
650-750, little more when cold. 4200 psi at wot. and it will hit 4200 way before 4000.
Extended Power
So is there a point of over pressuring the system?
Would a code come up if you take it too high?
kevin
springdale wa
I would like to to see some more icp guage videos.. I just installed one on my truck and it seems very erratic ...
windrunner408
Do you mean it bounces all over the place with pedal/throttle position or do you mean it just changes a huge amount with a small change in throttle position??
