ICP pressure
kevin
springdale wa
Do you mean it bounces all over the place with pedal/throttle position or do you mean it just changes a huge amount with a small change in throttle position??
I get a huge pressure spike on start-up like 3500 psi then it settles back down to 550.. then cruising down the road when I roll into the throttle it hold at around 1500 then bam it goes to 3500 then stwrts dropping off a little
STROKEDOUT
NC
In for info, mine is 650@ idle 2200@ wot. :confused:
Sent from my ADR6400L using Tapatalk 2
