444getsitdone
I have been driving the truck for probably 8 years with that code (p0308) is came from the CPS so I knew the injector and cps were good so I just ignored it. but after 2010 when smog came out I had to get that light off. Took it to a repair shop and after replacing the CPS and injector no. 8, which did no good the tech replaced the CPS with a on old style "black" IIRC and that took care off the check engine light. got it smogged and everything was cool then the CPS went out, they replaced with a used black one again and it went out again so they just put in a regular Ford one in and it was fine with the check engine light. next smog I had to get that light off so I personally just to see put in a napa CPS and the light went out and I smogged it, then the CPS went out again. so now I keep the a new napa one for smogging then run the ford (or international one its the same result of P0308) CPS. Now I have no problem switching CPS's every two years but I was wondering the other day if the PCM thinks that Cyl 8 is not doing well will it derate or totally kill that injector? I think it runs fine for a truck with 376k miles, but then again sometimes I think it may have a slight miss. What are your guys thoughts?
