IH water pump with filter.
Big Bore
9000ft in the CO Rockies
What's wrong with using the t-stat that International designed the motor to have in the first place?
I'm not positive on the specifics of this, but the advantages of having a conventional diesel engine at an optimum temperature to facilitate a better combustion have to be weighed against the side effects of using oil that is 8 degrees warmer in the injectors/HPO system of the 7.3 Powerstroke, which (especially in the case of dual/higher flow pumps) becomes even hotter, and is then dumped back into the crankcase into oil that is already 8 degrees hotter, which then raises the temperature, which is then run back into the HPO reservoir, through the injectors again, etc etc etc...
Ford changed the t-stat for a reason. So I guess at that point you have to decide whether to go with Ford engineers or International engineers. Finding out why Ford changed it would be a good place to start, but I'm betting it's related to the HPO system.
AZStang
Tucson
I noticed last night that I have a small coolant leak coming from the little ball valve on my pump. The one that shuts off the flow to the filter so you can change it. I called the manufacturer, http://www.geomarheavyduty.com/onlinecatalog/WaterPumps/Navistar7p3.htm, and was told the only fix is to replace the pump. He said the pumps with the little ball valves are a poor design and prone to leak. When we began our conversation, he assumed I had just installed the pump and told me to exchange it for another one. He seemed surprised when I told him it was 3 years old and had 30,000 miles on it.
Anyone else run into this yet?
Shawn
Peroni
North Carolina
Shawn
Never heard of this before, I know mine is not leaking. It does not look like that a big a deal to remove the valve cylinder and replace the o rings on it with something that will take the heat better.
AZStang
Tucson
I called my Navistar dealer and they can get the valve assembly pretty cheap, but nobody in the shop there has ever replaced one. The manufacturer said it was pressed in. My fear would be that once out, it would no longer stay pressed in.
Shawn
Tom S
I would also be concerned that the valve on the copy one is not exact to the original
Peroni
North Carolina
Shawn
The valve can't be pressed in otherwise it wouldn't be able to turn. IIRC there is a retaining clip that holds it in but its been a while since I put my pump on.
I would not trust what the manufacturer says. Likely the only person who knows exactly how that valve is assembled is the guy who designed it and the guy who assembled it! <-- Very typical with manufacturers in my experience!
AZStang
Tucson
You are correct! I took a look tonight with an inspection mirror and there is a small snap ring on the outside. Probably have to pull the fan to make enough room for access, but I should be able to get it out and replace the o-rings now.
Thanks!
Shawn
AZStang
Tucson
Well the bearing in my pump let go sometime in the past two weeks, so I never did try to change the valve out. It went in a hurry too. I had no leaks at the weep hole two weeks ago and there was a huge amount of play in the shaft when I took it apart this weekend. I'm glad I caught it when I did.
This pump was a new unit manufactured by Geomar Heavy Duty. It lasted 3.5 years and almost exactly 30,000 miles. I don't know if that's normal or not, but I'm not very impressed with that life.
Anyway, I bought the new pump at International. Price was $215 and it is a new build. The box it came in said PartSmart on the side. The guy behind the counter said it was a new supplier International is using in order to be more competitive on price. Hopefully it will last longer than the last one. I also found this site when searching for a replacement. I don't know anything about them though.
I did pull the little valve out of my old pump after I had it on the bench. It is pretty straight forward and only has a snap ring and a single o-ring sealing it. Should be easy to the replace the o-ring if anyone ever needs to.
Shawn
Got4wd
So I picked up a international pump today and I will be doing the extra pulley set up. Question I have is, does the stock pulley that mounts to the fan reused or do I need the international one? I have read that it needs to be clearanced?
AZStang
Tucson
Much easier (and cheaper) to just grind the pump casting eliminating the need for the extra pulley and use the stock length belt. That's what I and most others have done.
Shawn
Got4wd
Shawn
So what is the extra pulley for? And does the original pulley need anything done to it to make it fit?
AZStang
Tucson
I don't know what the extra pulley is for. International trucks with the 7.3 have it and Ford trucks don't. Your stock fan pulley works fine with the International water pump without the extra pulley.
Shawn
Got4wd
Shawn
Ok so the "stock" pulley where the 4 bolts needs no modification? It just bolts up? Seems that I read somewhere it needs to be shaved down on the back side?
Peroni
North Carolina
It bolts right up the pump but you either need to grind two clearance channels in the pump body or remove about 1/16" from back of the pulley rim. I have a lathe so I did the latter.
Reread the very first post again carefully. Billy and myself make mention of needing just a little clearance on the pulley. It may have just been our pump castings. I strongly suggest you try the pulley on your pump before installing it.
AZStang
Tucson
I'm on my second international water pump and I didn't have any clearance issues with either one. I wonder if the pulleys changed as some point.
Shawn
