injector questions
caruso88
Detroit maine-dothan Alabama
Hi my names Scott I'm new hear I have a 95 f-350 4 Dr 7.3 5 speed I have ao code injectors I need to replace them what would in have to do to run ab code I know ao-aa are 90cc single shot and ab are splittshot I happen to have a complete set of good code ab any help would be awesome also can I make them a better with aa parts if had lots of 7.3s bet never played with the injectors much thanks
Justin@DP-Tuner
You will just need to get custom tuning to run them in your OBS. We can help you out with that. Many options available... https://www.dp-tuner.com/ford-powerstroke/ford-powerstroke-7-3l/tuning.html
Let me know if you have any questions.
I would not tear into the injector yourself unless you know what you are doing in there and have a flow bench to test once you are done. I have seen many guys bring on a huge headache for themselves by going into injectors without any prior experience or knowledge. This is one thing that should be left up to the reputable injector builders. You would be much better off just using the AB codes or sending your AO codes out to get re-maned.
