injectors reg return or not
brownbros-ben
FRANKFORD ONTARIO
I am planning to run, 190/75 injectors, in my truck with 66mm turbo.
I just wondering on peoples thoughts, do you have to run a reg return kit?
I have 155/stock tips now with banjo bolts, blue spring kit, stock fuel pump, fass with filters lift pump to stock one, sump kit in tank. and I run at 68psi normal 62psi wot.
mind if I smoke
Knoxville, TN
I always recommend putting in a R&R kit when going to bigger injectors. Imo it's better to have the fuel/pressure and not need it then to starve the injectors.
04cr450
harford county, maryland
Im with these guys^ great kit... Even though I don't have a RR, I have 175/75's and since I installed a 6.4 pump as a pusher to the 6.0 hfcm my fuel pressure stays still at 60-62 psi(with a stock spring not a blue spring- took blue spring out after this). Surely was a good mod I did, just giving you another option.
