Intake for 6637
Willman940
Fairbanks, AK
My name is John and I have a 99.5 7.3, I bought it with K&N that was dirty with a rusty airbox top. So I replaced it with a 6637 kid from Riff Raff. I like it fine but I'd like something that wouldn't have the filter right up against the fender and would incorporate my filterminder and sensor. Is there anything like that out there or am I better off just drilling 2 holes in the pipe?
Thanks and enjoy your weekend,
John
2000wa250
Filter minder wont tell you anything with the 6637. It flows so much more than stock that it could be mostly clogged and still not suck down the filter minder. As far as right up against the fender, the end of it is closed and solid rubber, I wouldnt worry about it too much.
If it bothers you that much you could always either cut some of your rubber intake, or weld up a custom pipe that puts it where you wanted it.
Tree Trimmer
in that pic, you can see the clamp that goes around the filter. that is easy to make. make one, and you can mount your filter anywhere you want to, and have it stay there.
