Intake manifold
ODAWG714
Orange*County, CA
I had a turner tell me the tow tune he sent was for 190's and tha my temps should be lower. How much to get them flow tested?
Damn man idk. I'd contact the injector company and tell them something is wrong. Before that though I'd eliminate any possibility for any boost or exhaust leak. Make sure your manifolds are tight make sure your up-pipe is properly seated on your turbo, take the v band off and physically check. Check your egr cooler v band if u have one.
My manifolds were loose as Fak to the finger. So just a helpful thought. Also check your cac tubes and your map sensor rubber hose that goes to the intake manifold.
If all that is good get some different 155/30 cause that ****tt isn't normal
strokin6L
Springville NY
love my No Limit CAC pipe
