Intake plenum v bands
bens
Just out of curiosity, has anyone seen v band intake plenums, that v band to the spider as well? Or just use the bolt connectors(not sure of the term) to prevent the boots from blowing off.
m_j
I have images of a red motor using v band plenums.
I havent popped that boot off, it usually the turbo to intercooler on mine
bens
Would you mind posting them or pm please, id be interested to see. Im running a custom air to water setup and it as well as my pipes have some good "barbs" although im looking to fab some v band flanges there just for ease of mind.
Vader's Fury
Chesapeake City, MD
Most likely it is dave's truck from Alaska. Looked great!!
Most issues arise from the boots that go on the cold side pipe and not those in the intakes.
Hotrodtractor
Mingo, Ohio
I've done a v-band on one side and maintained the boot on the other plenum for misalignment - it makes installing and securing the y pipe pretty easy.
powerstroke95
Batesville,IN
Id say HRT has the right idea. With a Wiggins clamp, Im pretty sure your alignment would be crucial. Even just eliminating one of the boots would make install way easier
bens
Im liking the idea of 1 v band and boot on the other, the v band should keep the spider from wanting to move around blowing the boots off. Thanks for the ideas!
