strokin64l
I know there is really no difference in intercooler pipes in lower egt sense but what company makes a hot and cold side that requires no trimming sorry if this has been touched on before didn't see anything anywhere
i sell a hot pipe that is 2 piece so you can remove it without pulling battery tray . as for the cold side, if you want a cold side that doesnt require trimming, dont bother, because you arent gaining anything. for just a few minutes with a grinder or dremel , you can improve airflow alot.
http://nolimitfabrication.com/index.php?route=product/product&path=67_73&product_id=51
Looking to do intercooler piping,intercooler,mishimoto rad. and boots only because I have to replace an egr bung above the front cover so I wanna get the other stuff on there now so I don't have any reason to pull the front end out for awhile
Look at the MANY options available via AMAZIN' Amazon if we wanted to try a universal I/C that is comparable to the factory unit. I wonder if one of those CRX 'coolers would work in the 6.7's! http://store.max-redline.com/index....et-2-air-outlet-0-73-liquid-inlet-outlet.html
https://www.google.com/search?q=Uni...sch&q=Universal+air+To+Air+Intercooler+5x5x15
