i think my answer is correct.
Agreed.
I was thinking the grille would lower the radiator temp or at least lengthen the time it takes to get above a certain temp.
Think pressure cooker. Holds x pressure, raises boiling point x amount. Plus your not using water. Its mixed with coolant. Coolant raises boiling temp and lowers freezing temp.
My motor does NOT burn any coolant, not even when i drove with 12k hooked up to the back for 1500 miles from reno, nv to wichita ks... If your losing coolant you're leaking somewhere.
Same with oil. Yes CCV does allow some to escape. A very small amount. And I don't know the boiling point for motorcraft 15/40 but I've never had more or less oil after 3000 miles. if you are losing oil, I would look for leaks.
Uhh not under pressure its not. At 30 psi above atmo its 264°. I hope your running at least 30 psi of oil pressure. If your oils hitting 260° you got issues. IMO that theory ain't worth a ****.
Sorry matt, I do love your tunes though
Just over 3000 miles in the last 4 days... Drove from Cedar City, Ut to LA, Ca. Air temps were 105-110 and the coolant temp hovered right around 190*-200* with oil temps right about 5* above that. This was of course empty, not pulling but I was very happy.
Pulled the trailer from Bellingham, Washington to Alfalfa, Oregon and back. Still saw some high oil temps on the big passes but they recover quickly.
I am impressed. Joey and I don't see eye to eye on much, but I like this T-stat...
Read the end of post #107
Well what does it mean when my fan is on continuously?
Try to turn it by hand, there should be resistance. It shouldnt just freewheel.
K ill do in am... But is the fan suppose to be turning all the time? I've never heard it "roar" like I've read
yes, it always spins but free spins like ty said... when its kicked on it will sound like a 747 under the hood.
