You'll have a blast. Who's doing your tuning? If Cale is doing it you will basically need to same tunes I have. Unfortunately because you have an OBS it wont be as easy as just burning mine onto youre chip. If you do go with Tyrant tell him you need Palmer's tunes. I should have my tunes adjusted by the end of next week so if you can you should wait until then to install everything.
Obviously if youre not going with Tyrant none of that applies. Make sure that you talk to jake and make sure you have the right height pedistal as well as the correct length drain tube. Better yet request that you get the flex line for your oil drain.
Also, make sure that you have ZERO boost leaks. You may feel like you're fine and the turbo will still spool, but if you do not spool constantly you have a leak somewhere. I thought mine was fine and it just built boost really fast after it lit, but I had an exhaust leak which is why it was somewhat laggy until 10 PSI. Also, easiest way to install it is to bring it straight in through the valley. Make sure you give yourself plenty of time as you will be replacing your plenums and the RTV needs at least 12 hours to set before being put under boost.
btw, could a moderator change the title of the thread? I just realized its 468 when it should be 467
