a_moore
I'm a KSU alumni..graduated in 2008
EMAW!
I think it could be fixed with a little more idle timing but Jon would be the one to answer that for sure.
If you have a scanner make sure you oil temp sensor is giving correct readings, if its off it greatly effects all of the fueling and timing tables.
mine does exactly everything your saying mileage is crap too..... and live tunes are WELL worth the trip down there..... do you have bdp tunes now, and how long have you had them? and what are all your mods and how long have you had those
:whs:EMAW!
Should be pretty close to coolant temp, drive it around for awhile and it should atleast reach 180 degrees.
