okay, ive got a 96 7.3 4x4 5spd all stock besides 4 inch exhaust with stock down pipe and a cone filter. I notice when the truck warms u that the idle slighty goes up then down up then down. barely see it on the tach. kinda sounds like ac clicking on then off. is it normal? could it be fuel filter? I just got it about a month ago and don't know last time it had been changed. Also it has like no get up and go until 2000 rm and up. Is that normal for a stock truck? I plan on doing a set of injectors and probably an adrenaline hpop this summer. plan on buying an edge evolution soon as I get the money.
ok. So you say the idel goes up and down...is it only during the first couple of minutes(like 2) that you atarted it or once after its done been warmed up?
Check for oil and fuel leaks.
You say it has no get up and go till 2000 rpm...check the up pipes for leakage, as well as your intake boots for leaks post turbo.
As for the injectors and HPOP :thumbsup: good deal, but NO NO NO NO to the edge programmer.
First of all they suck period. On bone stock trucks. Have been known to cause alot of problems like locking to your truck. And when upgrading to bigger injectors an edge programmer is completely pointless to the affect you might as well me loosing power.
Get a TS style 6 position chip. With ANY of the many custom tuners tunes on it, most of which are sponsers on this site and can be found here. For example, Tony Wildman, Swamps, Beans/NLTD, Gearhead, Tyrant, ECT. They can custom tune, tunes to your specific truck and the mods you have done to it to optimise power and fuel economy. Where as the Edge can do no such thing. Even if you withhold from doing bigger fuel and oil mods, custom tunes will benefit you very well.
