Jodaddy modded Efuel for Tightwads?
94.5stroker
Phillipsburg Kansas
Aight so some of you may have seen my thread about fuel pressure and fuel leaks, but essentially I am just sick of fuel leaks, and I think that my stock fuel pump is on its way out. I have replaced all of the orings and fuel lines at the fuel bowl, and built a fuel pressure gauge and tested my pump. I will post up a video of my fuel pressure when I get my phone to hook up to my computer. But anyway I would love to do a full E-fuel conversion, but unfortunately I don't have the funds right now.
So here is the solution I came up with, and I was wanting to get some feedback from you all to make sure I haven't missed some fundamental issue with trying a mod like this:
I want to use JoeDaddy's "tightwad mod" to mod my FPR so that I can put a new mechanical fuel pump (I can get it at my employee discount) and delete my fuel bowl. Here however is where I want to differ, instead of just placing a single filter/water separator between the low stage and high stage of the mechanical pump, I want to put both pre- and post-filters on the frame rail, inline between the tank selector valve and the fuel pump just as you would with a DIY E-fuel set up. That way when I have the money all I will have to do is buy a SD fuel pump and a fuel regulator (which seem to be the expensive parts) and hook/wire everything up. I also have access to a CNC machine, so I will be able to fab up the brackets to hold the pre/post filters (and eventually SD pump). So for the time being, I will just have my pre-filter feed into the post-filter. (a little redundant I know, but it will make things easier down the road I think) From there I will tie into the (new) mechanical pump using the factory line, and than just tie the low pressure outlet to the high pressure input on the pump. Then on the return side, I will just use JoeDaddy's mod to regulate the fuel back to the tank.
The question is, are there any major issues doing it this way? Has anybody tried this? And most importantly does anybody have an FPR to donate to the cause haha???? I realize I would be better off with straight up E-Fuel, but I just don't have the money right now, and while I have access to the machinery to make a sweet mounting system I would like to make everything so that eventually all I have to do is buy the rest of the stuff needed, and convert to E-Fuel.
Sorry so long, and thanks in advance,
Nick :ford:
94.5stroker
Phillipsburg Kansas
Here is the video of my fuel pressure idling:
[/URL]
Anybody know if this should work, or think of anything I may have missed?
Yodersstrokin96
Alvada, Ohio
so you want to run the feed through prefilter, up to pump back down to post filter, then back up the the motor then regulated and back to the tank? thats 4 fuel lines on the rail you can get filter bases shipped for NAPA for 70 bucks then fuel pump for just about 100 use old regultor hook up lines and bam..
94.5stroker
Phillipsburg Kansas
I was gonna just run it through a pre and post filter, then up the stock feed line to the stock pump, then through the heads and out to the reg and back through the stock return line, but the general consensus was that the stock mechanical pump wouldn't be able to pull the fuel through the two filters on the low pressure stage. So now I am just piecing together an E-Fuel set up.
I've ordered the filters, and am gonna get the pump and bracket from a salvage yard, then just reuse the stock fuel lines and do the joedaddy mod on the stock FPR. That is for now, eventually I will just buy a regulator and put it in place of the modded stock FPR. Tryin to make this on a budget, but at the same time do it in a way such that I can go back and add the "nicer" parts as I get the money/need for them. Just sick of leaks and low/inconsistent fuel pressure.
