Keeps blowing injectors
Gearhead
replace the icp sensor.... if it is under-reporting the oil pressure it runs it high all the time which causes un-necessary stress on the injectors. Now if the injectors weren't assembled correctly and the bolts were over torqued on the bodies, I can see them breaking like that.
SledDogg
Ann Arbor
1 new injector, new IPR were installed. Shop I deal with when Gary doesn't do my work said that low fuel pressure has caused this in several trucks that they've seen. I know my pressure is good though.
SledDogg
Ann Arbor
ICP will be replaced soon, just as a maintenance issue. Put 132,000 miles on truck in 8 months. EBPS as well.
SledDogg
Ann Arbor
Funny, it was #7 that blew apart. #7 & #5 oil rail sockets had been repaired because #7 was leaking after head gasket job.
Dealership said rail repair sockets were purple in color if that means anything.
I will be replacing other 7 sticks soon. Guess that I should replace/repair all rails/sockets.
Jeremy @ No Limit
Athens, Ga
Ummm no. Low fuel pressure WILL damage an injector but not in this way that happened to yours. You might need a new mechanic.....
SledDogg
Ann Arbor
Low fuel pressure causing it was from injector warranty reps. Just repeating his experience. They tested for fuel pressure on those trucks. Maybe it was just part of issue....I am not knowledgeable about this. Always learning.
Gary
South Lyon Mi
This is what low fuel pressure causes
That top backer ring was probably cracked by the guys that put those top injector seals in, I'll bet they were fighting the snap ring and cracked it, then reused it. Those backer rings don't just fail.
