Let's talk gates and back pressure
Dzchey21
wyoming
to small, not enough air. looking to go big Ivan, probley 72mm with a 86mm or somewhere around that. big hybrids and more spray.
im running an 86 and was running a 71... decided to downsize to a 63 to help spool up, pretty much guarantee i dont loose power by going to that...
nvme_63
dryden mi, lima oh
same turbo i have and the exact same thing i've seen. When i dyno'd a little while back....i saw boost almost to 45psi and back pressure around 53-54psi. It's been a darn good turbo so far being non gated. Just wish TP gave us a better pedistal and drain for it. But that can be changed i guess.
I honestly don’t have a gauge hooked up to keep an eye on drive pressure (I know this is dumb). But I do know I have enough drive pressure to keep blowing the Bessel’s out of up-pipes. I have done it too 3 sets in the last 8 months. Time for custom headers, up-pipes, dual gates and compounds.
With that being said, I would contribute part of the problem to the shi**y pedestal it comes with, I think when it gets hot the weight of the down pipe, and the flex of everything is stretching the Bessel’s of the up-pipe. If you follow what I’m saying.
Extended Power
If you still had that Turbo from T.P. what would the other Turbo be on that set up for twins. That is the Turbo I am running and I am looking at going to twins just for egt 's.
Do an S480 with race cover...fairly standard.
motoxracer42
i didnt blow out my flex pipes on my stock up pipes until i was pegging a 100psi gauge, and the only reason it broke was that the tbolt on the vband clamp actually snapped under pressure. i think your problem is the pedistal not supporting it enough. if your running a 64/71 then you could run a decent sized atmospheric charger under it to put a smile on your face. at least you wouldnt lose spoolup. i ran a 71mm turbo as my secondary this year and they dont spool well at all. most of the time it wont spool up without a small shot of nitrous.
Extended Power
I wasn't crazy about my 66/71/80.
Bought a billet wheel for it, and opened up the wastegate ports in the .70 housing.....was gonna try that before parking it for the winter...but who would have thunk I would be parking it in August...
