Oh yeah i plan on posting a detailed one. only downfall is it is 4WD so i cant get it as low as id like, but we will race it so i needed it. Whats the set up of the truck on your avatar?
Thanks bud i rub a little on my drivers side.. i had to grind off about 1/4" but that was at full turn... no bid deal, but id imagine 37s on my wheels would require a lot of trimming.... I want to do the same tires and wheels but just leveled with 35s and 22x11 or x10
I may have a set of coils for you- stock 4wd spring rate and 3" shorter. Sourced them from Deaver. Shoot a PM if you want, and I'll give you my number.
Changed some things up on my pile.
Changed to all black mirrors, put power steps on it, swapped to open lug style Fue center caps and 15% tint on the windshield.
What would one do with the rear of the truck to drop it that low as well? Just remove the block altogether? Also, the shocks, factory height seems like it'd be alright, no?
If you don't mind me asking how did you make open lug style fuel center caps work on those renegades?
I removed the 4in block and put in a 5in block and a AirLift 5000 bag kit. Looks much better now with no lean to it. May add some Traction bars just incase
Best shop in Houston hands down!
Keep up all the good work & customer service!
:ford:
I want a sticker too!!Thanks buddy!!
Thanks, it's 8" with 22x14 and 37's.
I'll be there for my EGR delete...
'13 350 with icon 2.5 & 295/65r20 nitto trails
