Lifted 6 inch...need new gears??
Animosus
Laramie, WY
dseitler
Royal Palm Beach, FL
I'm guessing that's at 65 MPH. You would have to Do the following to figure your RPM for a 2011 and up SuperDuty
RPM X.67 6th gear @ 65mph
RPM X.86 5th gear @ 65mph
bricewise
I'm not quite sure I understand the formula your giving.
Is it RPM X .67 = 65? If so 65/.67 is like 97 something.
dseitler
I'll just pic a number or RPM
Gear ratio is 3:55 with 33" tires = 2349 RPM
Say you want 6th gear but you have to divide in the final ratio output of the transmission to get you true RPM at 65 MPH. In this case it's .67 The chart is based on 65 MPH.
2349 times .67 = 1573 This should be your RPM at 65MPH with 33" tires in
6th gear
2349 times .86 = 2020 This should be your RPM at 65MPH with 33" tires in
5th gear
Jesse_01
Prince George, BC. Canada
So if 4.30 for 37" is the ticket. Would 3.73 & 35" be a nice fit? I can get front and rear done for $1000 otd with ford gears. Trade my diffs for a gas f350 3.73 diffs with half as many miles.
