LOCK or FREE?! HUB Help
anthony02tolson
valparaiso Indiana
So I have had my 08 superduty for about 4k miles now. Lariot 4x4 off road edition. 4X4 shifter on the floor. Have used the 4x4 on a few launches and that's it. Well I just noticed today my front hubs have been locked since I bought it. I turned them to free as soon as I noticed. Could I have hurt anything running them in locked for so long? Also will I need to get out and lock them whenever I wanna use 4 high? Thanks a ton.
Anthony.
907DAVE
AK
Just a little extra wear and tear on the front drivetrain and slightly worse fuel economy, but absolutely nothing to worry about. Heck, Ford is the only one left that gives you the option to unlock the front end.
And yes, they need to be locked in for 4X4 to function.
powerstrokin15
Charleston, WV
i thought in "free" they were like the auto function. they kicked in when you engaged 4wd automatically..? and lock would mean the hubs were engaged regardless 2wd or 4wd
Atsah
Maine
That is the way my 6.0 was.. It said "auto" and "lock" but I had the switch on the dash not the handle on the floor so it could be different..IDK
powerstrokin15
Charleston, WV
mine was the same way.. ive never actually even looked at my 6.4, just assumed it was the same LOL and ive used 4wd a ton
but on edit i see he meant floor shifter :doh: sorry... i need to read the whole thing
SICKS LITER
Salem, NH
you can leave them locked if you want. it will just hurt fuel mileage a little and add wear / tear on the front end.
co04cobra
WV
Holy **** guys. Its just a plain old set of lock in/ lock out set of hubs. They are 10 times better hubs then the auto/lock ones. If you have a esof t-case somebody probably switched them out to straight lock outs b/c the other ones are junk.
I think that it is great that ford still offers this. It helps with fuel mileage and you have a 2wd lo range option.
If you are going somewhere that you MIGHT get stuck lock them in before you leave. Otherwise just run them unlocked.
Dzchey21
wyoming
Actually they are the same hubs only difference is there is a vacuum diaphragm on the front side of the hub when set in auto or unlock the vacuum actuator pulls the hub into locked. Bad part is any sort of vacuum leak or debris in the hub can cause the hub to.not fully.enguage causing damage.
I have made one good hub out of two bad hubs one was an.auto hub and one was a manual hub.
co04cobra
WV
From what I have seen on the auto ones when they fail they start running the front axle. Have you had this experience on this style hub? On the manual hub when its locked out it cant run the front axle. Seem right?
Dzchey21
wyoming
They are literally the same hub minus the diaphragm. Mine always explode the gear but never hurts much. Actually must if the time the hub won't unlock but seams to grab just fine when you need it. After time tho they will start making noise.
A.thoma
ohio
you dont have to get out if they are in auto it locks in after 1/4 of a rotation if you lock in the hubs they are automatically locked in if your stuck stuck
Worstenemy453
Fredericksburg, Va
Ok what ?
Anyway, i have always left manual hubs locked in on Fords during the winter, and most of the time during the summer, never had any issues what so ever.
My 86 F250 had them locked 75% of the time, my blue 89 F150 had them locked 75% of the time and my black 89 F150 had them locked 99% of the time. Ford knows how to make hubs.
8inchstroker
AZ
I prefer the hubs to been locking/unlocking.......kinda ol skewl compared to the other trucks/cars.(GM/DODGE)
DRUNK FINGERED FROM DROIDX
Erikclaw
Central CA
Is there a way you can grease these front hubs to keep them turning.
That is pretty much how I fixed mine when they didn't auto lock. Took them apart, greased everything and put some grease on the o-rings.
After reading the rest of these comments, I still think I will go the manual locking route and the Dyna track free spin conversion. I hate having a vacuum line controlling if it locks or not.
