losing coolant found small leak
beanz15t
el paso tx
Sweet sounds like yet another reason for a 12 pack and day in the garage turning wrenches! One more question have the dual oring plumbing failed anyone since the install? Thanks again!
webb06
Seneca, MO
Never seen or heard of them failing. Gates makes some aftermarket versions that are a little
cheaper than oem, same quality too.
TjMiller
Brick NJ
I did the hoses and t-stats while I had the coolant out to remove the coolers. Hoses were a snap, I could see where the old ones had been weeping past the o-rings. I could see the t-stats being a chore with the upper cooler still on, they really freed up some room in there.
