I have a LOT of parts and i want to sell some of them to clean out my garage a bit. I'll keep the first post updated on whats for sale and the prices, so you don't have to keep asking if certain parts are still for sale. What you see in this post will be accurate and up to date. Prices are negotiable, and do not include shipping. Most of the stuff i'm just guessing what they are worth so don't be afraid to make offers. Worst i say is no. I won't be insulted. All parts are for 7.3's unless noted. All listed as T444E parts came out of school busses.
7.3L PSD long block - it has either a blown HG, cracked head or cracked block, i don't feel like screwing with it, comes with front cover, pan, rotating assy, heads, rocker arms, pushrods and HPO lines - $200
OBS style UVCH's - $75 for the pair
7.3 valve covers - $75 for the pair
Trans to engine spacer plate for E4OD - $100
Flex plate - $50
Used water pump - $30
Oil cooler - $50
Air Conditioning pump - $75
Accessory brackets for OBS - $40 each
OBS Turbo - VERY minimal side play, no end play - $150
OBS Turbo pedestal, i have 2- $50 each
OBS exhaust manifolds, i have 2 sets- $50 per pair
OBS fuel lines, these have the quick disconnects up to the pump - $30
OBS engine wiring harness - $100
Black CPS - $30
ICP sensor - $40
LPOP - $40
Assorted battery cables - i'm not gonna give them away but make an offer and tell me which you want, i have + and - cables.
T444E power steering pump, mounts above HPOP - $50
T444E to allison trans adapter - $200
T444E to allison flywheel - $100
T444E fuel bowl - $50
Crank pulley, i have 2 - $50 each
T444E PCM, i have 2 - $150 each
OBS fuel pump - $25
SD style exhaust manifolds - $50 for pair
15* HPOP, i have 2, one has about 150k miles, other is around 200k i believe - $150 each
NP273? transfer case, SD ESOF for 4R100 - would like to trade for ZF6 tcase or enough money to buy one, $400
F-150 PCM, code YAZ3 - $100
OBS passenger side headlight - $30
OBS tail lights - $50 for pair
Cylinder heads, came from blown PMR engine but no damage other than a bent glow plug tip - $200 for pair
Flex plate - $50
Oil cooler - $50
Black CPS - $30
ICP sensor - $40
LPOP - $40
OBS fuel pump - $25
