lowerd/leveled 6.4l truck pics
OOWeaver68
Southeast Texas
I think your truck looks perfect, honestly that is the exact proportions I want. But I already rub just a tad in the front on the spot where the fender hangs down. Does your setup rub bad at all? And is your truck an f350 or 250? As far as the rear block height that is...and what leveling kit?
Thanks for the help,
I'm interested in this to say the least lol
Edit: nvm, already answered the lift specs. But does it rub at all?
Its a 250. Here is a couple pics I took when I first put them on.
Front driver tire
Front pass. tire
I trimmed the finer liner quite a bit. Also I loosened up the bolt at the bottom outside of the bumper and hit the back plate forward. That moved enough to clear the tire.
Frank_C
Orlando/Jupiter, FL
Aye,
room doesn't look too bad actually. I might need to go down to 12.50's though. I believe that's what the trail grapplers come in right? I've got a feeling my 13.50 toyos might be a no go when turning
David S.
Aye,
I'd say 13.5 would rub for sure
Trav-O
TN/KY Line
2.5" Readylift with rear 6" Springs and 1" block.
2.5" Readylift with 5" rear block. (Same lift as my crewcab but sits 1.5" taller.)
Wojo
anybody running the 305 45 22's how long are your tires lasting. im dropping the leveling kit off mine and pulling the rear block and ditching the 37's in favor of some General Grabber UHP's. Just curious how many miles i should expect out of these things.
Dzchey21
wyoming
Im running original proxes with the softer compound I have 3k on them and I can already see wear on the front. I would say they will last 25-30k
Sent from my DROIDX
Pahrump
Beaumont..err Vidor Texas
I only got like 11K outta the Nitto 420s in that size....but hey they are cheap tires..all 4 cost just a hair more than one of my 41s
Dzchey21
wyoming
Good point mine were 675 shipped to my door for the whole set
Sent from my DROIDX
Jeff@Spartan
Georgia
Sent from my DROIDX
I'd be very surprised if you got more than 25,000 miles out of those tires.
MINK
London,OH
I'm at 20k on my nitto 420s, Theres plenty left for another 10k, like said they were only 700 mounted and all... I tow with mine along with a handful of burnouts, I'd buy another set.
Frank_C
Orlando/Jupiter, FL
I'm now 100% sure I'm changing my setup, traction blocks are now coming with 3.5" rear blocks and ordered some parts for an Icon leveling kit. Will have pics in a few weeks when it's all finished :D
