Josh@DirtyDiesels
^ that looks awesome! Similar to mine it looks, just a touch high in the front? Or is it level? Hard to tell by the angle of the pics
Next to a Taurus.
What size tires Jeff?
Where are you guys getting the 5.4 springs? How much? Whats the drop in " from 6.4 to 5.4 springs?
Looks good. Sits like mine.
Thanks. Debating if I want to drop the back more and maybe even cut another half coil on the front. Would have to modify the bumpstops though because right now its maybe 1/4" off them
Do it!
maybe pull the overloads or something... I like the little bit of rake it has now but it can definitely go lower!
Pull the overload. Cut the coils again. Trim one full nub off your bumpstops. Add a set of helper bags out back for when you tow and ditch the side steps. Done
maybe half a coil and no over load. planning on getting bags anyways and side steps are coming off asap. Just got my traction bars on today and the steps block the custom logos on the bars so steps have to go
finally got the front of mine lowered today. cut one coil off my spare set to see how it would sit. Rear is stock springs with block removed. I like the way its sitting now just slightly higher in the back. 20x10 wheels with 305/50 420s
