Lowered truck shocks
Platinum15
Sulphur springs
Ok, just got my set of 4800# springs and new set of rear ubolts for my truck. What shocks are being used once the trucks are lowered?
my factory ones worked that same as when it was factory height.
Platinum15
Sulphur springs
Never had any bottoming out issues? I'm looking to go aftermarket but everything I see says 0-1.5 lift. Didn't know if I went with a shock that can cover 1.5 over stock would bottom out when dropped 2-3"
Lipka101
Maryland
I have bilstein for factory height. No problems here.
Jomax
Arizona
I am dropping using 4400# springs and was told the stock height king shocks would work.
That is what I am ordering.
Mike, can get you some sweet kings, PM him. He has some on his truck.
Black AOD
Ohio
I was about to post the same thing, I think Mike D. and a few others use kings on their lowered setups. He should be able to hook you up good!
Jomax
Arizona
Will have to reach out to him.
Thanks!!
Spring for the adjustable 2.5s, that's what I'll be going with to make the ride perfect.
He said he almost took out the hop on concrete freeways expansion joints completely!!!
Vader's Fury
Chesapeake City, MD
I don't know if my budget can cover that.
I was looking at the standard 2.0 shocks for my Excursion. With the swap to coil springs and going from cheap ass Napa shocks to Fox shocks I hope the ride will be much better .
c12driver
Hey gents, I am in the same delima....08 ECSB 2WD, slightly lowered and desperately needing shocks. Can someone point me towards Mike D.? or any other suspension expert?
UNBROKEN
No Limit Fab in the vendor area or shoot Mike (Bigrpowr)a message.
