wanting to lower my 6.4 and take out the rear block that should lower the rear 2 inches i know i need front springs out of a gas f250 but they have different spring rates what pound springs do i need to make it sit level with the back
I'm wanting to get a 6.4 and possibly go the lowered route. What else needs to be addressed? Or is it as simple as removing the blocks and swapping springs? Thanks4800# is pretty level #4400 is rake .
Yes just swap springs and remove blocks
I thought it was that simple, but not in crew cab short bed, carrier bearing was unhappy, needed to be re shimmed, that or mine is fugged up because mine would vibrate down at low speeds like up to 20mph so i said screw it and just put the block back in.
No problems at all with my CC/SB. That was with 4400lb and 4800lb springs.
Up front you need to raise the truck and support it with jack stands then disconnect the track bar, brake lines, shocks and then lower the axle and the springs will come out. The back just raise the truck up support it with stands on the frame then undo the u bolts remove the blocks, set the center pin into the spring perch and use new u bolts to hold it back together
there were no problems when the 4400lb coil springs went in, but the rear block was pulled on my 2010 fx4 offroad packed superduty it started vibrating, and i tow trailer all the time that will lower the rear of the truck that 3-4" and there is no vibration at all, but the block was pulled it had a vibration on take off. A few people have said maybe the block is masking something, i'm not a driveline expert but I know what my truck did.
