rods and studs will be just fine with that setup if your goals for more hp in future do the hard block now and be done with it pry 1.5" or so from the deck would be ok dont waste money on a girdle
aftermarket rods and studs would not be a waste of money.( sorry if i came across as just leaving the factory rods and adding studs) every engine is different. i run 400/400's in my sled truck with carrillo's, main studs, and a 1.75" fill. balanced the crank and checked alignment on mains after the hardblock was set up, no line boring was needed. ive ran this setup for two years now with no issues. also know trucks that needed to be line bored after the fill that have had no walk issues without a girdle. if your that concerned about a girdle mise well run a bedplate from swamps and fill it. dave will prolly tell you that they dont do many girdles anymore
Not Trying To derail But With Billet Rods, Girdle, And Main Studs Does It Still Help To Fill The Block? I'm Also Building A Motor With 350/200 And s468
Filling the block requires deck plates and main stud girdle in place to torque the block to simulate everything installed. Pretty sure one side of the block is done at a time and held so that side is flat for cement to cure flat. Then needs to set a while after that.
Interesting. I was always under the impression that both sides were done at the same time so the torquing would be identical to an installed motor. I never even considered one side being done at a time. Seems illogical to me.
