Lamont_24
The pcm is behind the e brake, its what the chip plugs into. IDM is a silver box under the hood. You have to pull the inner finder to remove the pcm but can change chips from behind the e brake.
I did a zf5 swap and kept my auto pcm because of the chip, it works great but you cant use a manual pcm in a auto.
Okay, mine is a silver box then cause that's what my chip is plugged into. When I got the truck it had one sitting on the inner fender well and one sitting in the firewall, the one in the firewall didn't work at all and the one laying on the fender well let it start up and run but not shift like stated above
And carquest sells them for like 140 to 200 depending on which one you get but I'm going to take my vin to ford tomorrow to see if they can back track and see what it had on it and then cross reference to car quests system.
