Max effort 369.
swinky
Eastern, Nc
Yea he is I am running 190s and am getting mixed reviews if 190s are enough some say plenty others say not enough
imo yes. A 369 will run great with 190s. My truck picked up .7 with nitrous when I had the 66. I'd be willing to bet a 369 wouldve helped me pick up .2 at a minimum.
KCTurbos
Sooo I'd be better off with a 369?
I dunno... I was just brainstorming. I was just curious what made your decision to change from s369 to 371. I know you personally tried a billet wheel and switched back to the stock cast BW wheel.
I have heard of many people actually testing these "custom billet BW turbos" and finding out they run hotter and make less power. I have not done any testing myself.
swinky
Eastern, Nc
Sorry for the long wait guys. S369 with a big 1.10 turbine housing should be here in time to run next sunday. I'll be monitoring drive pressure and will put as much nitrous to it as I can while staying below 55-60 psi.
swinky
Eastern, Nc
Charger is on the way. Should see some pretty good fuel only numbers then we'll be deeeeep into the 11s once the dual hpop goes on.
Anybody think a 300 charger crew cab with stock rods can make a 10.9x pass?
KCTurbos
Anything is possible with enough nitrous :naughty:
Are you gonna gate the turbo? Or just let off when drive pressure gets above 55-60psi?
What are you using to monitor drive pressure? I have this gauge to monitor EBP/Boost and love it. It is nice to see the ebp/boost spread.
http://www.kennedydiesel.com/detail.cfm?ID=637
swinky
Eastern, Nc
I like that a lot. I'll probably do the same. A gate will be added.
03mm
FL/MD
Cant wait to see what you do. I've been looking at getting a s369 and 205s.
shmoozer
I'd like to know how you like it if you do. I'm torn between a 66 or 69 for my 205's.
swinky
Eastern, Nc
Keep in mind I'll be running a 1.10 housing. Spool will be less than stellar
