it's arbitrary... you could scale it from 0-1000 or you can scale it from 0-800 or whatever... you can make throttle sensitivity/curve adjustments on the accelerator:torque
but you could also adjust throttle sensitivity by adjusting torque:fuel
or by adjusting duration
or by adjusting LBF
they all intertwine and adjusting any single one of them will change the truck in similar ways
When you have multiple engineers programming on the same platform, you strive to have the numbers correlate to actual numbers... but we're doubling/tripling the torque, so...
and when it's just you tuning on it, you don't necessarily have to follow someone else's protocol, you can just make adjustments where you want to.
I'm sure that's the ADHD/scatterbrain method and would make an engineer cringe to hear, but I'm not an engineer, I don't tune trucks for a living, and I'm a scatterbrain
