Mileage drop
woodsman
Just replaced the high pressure crossover line, ICP sensor, number eight injector and put on a Bean's D66 turbo. Prior to this it was leaking oil (hpx), had a slight miss and got 17-20 mpg. Then the turbo went out and I replaced the above items before driving 2500 miles cross country. I saw anywhere from 11-13 mpg with no load. Any ideas why? It runs pretty strong, max boost is 28 PSI and it trips a SES light on full throttle runs.:confused:
woodsman
Fuel filter drain got dirt in it and stuck open, that AC condensation drip? It was diesel.:doh:
goodie85
Watertown, SD
not to thread jack but I have a little tick if you will, that sounds like an exhaust leak kind of but I'm pretty sure its a boost leak? how do you check for boost leaks?
woodsman
I'm not convinced that was it. I'm still hovering around 13 mpg when before I saw 18-20. Goodie has a good question, how does one check for exhaust or boost leaks?
Diezel Dawg
Cheney, WA
I had a tick this weekend.in.mine Nd.ended up being an exhaust leak on my passenger side uppipe at the exhaust manifold
Sent from my EVO 3D on the East Side
