Yep take you time and separate each wire just enough so you can look carefully. Given you tried another IDM if the wires turn out clean and another OHM out shows it all good. I seems like it would almost have to be mechanical. Honestly if you do have the VC off again IMO it would be well worth it to borrow a compression tester. Even if everything turns out good on it you now have a base value to use for comparison if you ever have an issue down the road. I would certainly move the injectors around to see if the issue follows and you can inspect the o-rings at that time as well.
