Modded h2e info thread.
Derek@Vision Diesel
Canby, OR
I bought what was supposed to be an H2e. Not sure if it if, but its close to the same general size.
Compressor Inducer: 69-70mm
Compressor Exducer: 100mm
Exhaust Inducer: 70-71mm
Exhaust Exducer: 80mm
No clue on housings as nothing is marked, it has one tag on it but its hand engraved and doesnt mean much. Does not say holeset on either housing, but the housings bolt to the center section just like every other H2E ive seen.
ytee
Here is a few pics of my modded H2E.
ytee
I found a few more pics showing the difference between the old housing and the new modded one.
CSIPSD
Bend, OR
Thats not an H2e... Not sure what it is, I dont even think its a Holset turbo...
Derek@Vision Diesel
Canby, OR
Well it is a modded h2e, its called the "sled screamer". Beans built it but I dont know much more than that.
Where it said Holeset on the compressor housing has been ground down as you can see. But if its a dedicated sled pulling turbo i would of thought it would be larger than what it is, going by those specs isnt it just about the same size as a middle of the road modded h2e?
CSIPSD
Bend, OR
Its not like any modded or unmodded H2e I have ever seen.
Ask Bean... But Its a short scroll which is not Holset like, and its not a V-band on the compressor which is not Holset like.
Going by what spec? You have none?
jngreen
IN
I'm not an expert, but that kinda looks like an old Schwitzer or Borg Warner turbo.
Derek@Vision Diesel
Canby, OR
Alright guys its possible its not a h2e. I was just going by what i was told looks like its a hybrid of an s300 and a k31. Seems like the perfect turbo for what im trying to do! although that info was from 2007 haha.
Jake is going to make me up a mount and im going to run this thing ASAP and then ill know more. Its definitely in perfect shape and the compressor wheel looks like it may be Billet like they said in that thread
CSIPSD
Bend, OR
How about listening to people when they tell you stuff...:doh:
