jbkingranch
I'm going to hook a sending unit into my regulator and put a digital gauge on the pilar.
And yes sir you have been a big help.
Low FICM voltage?
Low FICM voltage or an issue with the High Pressure Oil System causing less then desire pressure there for not getting good fuel atomization.
Also I know you said you have replaced the injectors but this wouldn't be the first time I have seen bad remain injectors from Ford.
Try completely disconnecting or removing the banks system. We have seen then cause problems even when returned to stock. Try running with out it and see what happens. It's worth a shot IMO.
