MTW Stage 1 w/ stock fuel system
ajbond
I'm running a stage 2 and 175/75s. It pulls hard all the way to red line. Spools like stock or better. This is on our 03 eclb 6spd on 35s. Very happy with it, going to a stage 3 to clean up the injectors here soon. Will report back when I get it.
can not believe the stg 2 will not clean up 175. what is peak boost?
Gillette, WY
about 29, I think im having the same issue that everyone else is having with back pressure. I am going to talk to Matt at gear head and see if he tune it out if not I will run a mechanical limiter on the bp sensor
ajbond
is this at lower elevation? I am at 4500 which adds to my problen.
a pressure relief is what I came up with but is a bit more complicayed, needs to only effect top end and survive 1400 deg with out introducing these temps to the ebp or it will fail.
