Petro
Good idea man, I really like it.
Did this take away the ability for the water in fuel light to work as it should? Or is that detected somewere else than the pump?
How about f.p. @ wot?
I'd really like to know all the part numbers ( fittings and all ) if you have them, I'm looking to do a DIY fuel system for my 7.3 and adding a second fuel pump to the system so I can get some more power and clean up the top side quite a bit....great innitiative though, the product looks awesome.
Chad
Thank You, I don't have the part numbers for the fittings. I went back to he NAPA stores brass fitting cabinet and grabbed what I needed as the tech wrote down the numbers.
I am pretty surprised more 6.0 guys dont want to get rid of the expensive and lacking filter/pump set up. A stock 7.3 elec pump will run 400 hp all day long, so It will do fine on the lower tuned 6.0 guys. Like you commented a second pump could be added for higher power guys if needed.
