smokedout250
Okay I figured I would share my traction bar setup I'm in the process of build. I choose to use a single bar setup.
These are my plans for the brackets
I chose to use 3 link top links. I know they are not the best but this is a trial run, I can always change them later. I went to my local ag store and picked up some that are greasable. I'm hopin this will help with noise and life of them.
For the rear mounts I used some scrap plate I had laying around the shop. I was planing on 1/4" plate but beings the plate I had is 1/2" it will have to work (it was free). Beings I don't have real precision tools I cut some 5"x5" squares out using a torch..... I took two squares tacked them together. Then I cut the half circles out using my torch as well. after doing some fitting and marking the holes I trimmed my pieces down to give them a taper. I drilled 3/4" holes in them for the links. After making sure everything was good and cleaned up this was the out come
On the front bracket, I decided that welding wasn't an option. I feel welding on a frame is a no no.... Now that's just me.... So I went the bolt on way. I used and already existing hole on the side of the rail frame. I drilled two new holes on the under side of the frame. I used a 3 1/2"x6" angle iron to wrap the frame rails. For the bracket for the link I had some 1/4" flat bar that I drilled and cut to fit .
Hope to have this project finished up this weekend I will up date more as I go!
