Pstroke96
How much weight should I throw in the bed
i see you have access to a fork lift, put a pallet in the bed and push the truck down with the fork lift
Those don't look bad!!
Like you said I think 2" lower on the rear holes would help and then just some actual heim joints on the axle end and bushings on the top to help with noise/ vibration transfer.
Ballistic fab has horrible service there are many many other places like ruffstuff blue torch fab etc I would use before them.
and in case you weren't aware, i'll explain just what suspension bind is. if you already know, deal with it and don't read.
when your suspension compresses, the rear axle does not move straight up and down. as the axle moves up through the travel is moves back towards the rear of the truck. this is why correct angle of the bar is so important. if the angle is wrong, it will not allow the axle to move towards the rear, and this is where that tremendous additional pressure on that front bolt comes from.
the axle wants to go toward the rear, the bar either makes it go to far, or not far enough, it sits on the bar, so one of a few things have to happen. shear the spring bolt, shear the trac bar bolts, or seriously wollar some things out.
just pointing some things out.
carry on.
Hey Tree Trimmer,
I'm curious what kind of background you have with suspensions, traction bars, etc? Seems like you know a great deal, just wondering.
I have some knowledge as well, but I am no expert either. I am a bit rusty and need to double check my info, but would like to add a couple of things to what you have mentioned. You have made some good points that many do not realize or understand about suspensions and traction bars.
One of the most important facts that goes in correlation with what tree trimmer has mentioned is: the bars MUST be parallel to the driveline. This is another reason why you will get binding and/or issues as tree trimmer has mentioned.
this is incorrect. the angle of the driveline is just a starting point.
I would also like to add that traction bars typically need to be at least 54" long to be effective. This will vary for each vehicle depending on lift, wheelbase, etc.This is why the adjustable length OUO would be a wise choice.
there is no minimum, or maximum length
The mount on the axle needs to be a certain length, but I do not recall what the minimum length is. I want to say the minimum bracket length must be 2.5" but I will have to find out. If its too short, the design will not be effective.
I believe DOM tubing is the best choice, for many reasons, but I think there are some materials that will give good results as well. I would not use typical steel tubing, but that's just me.
do you know what DOM tubing is?? it stands for domestic. as in made in the usa. 2", 1/4" thick wall round tubing, is pretty standard. generally we have better steel, but they have cheaper steel.
I will post more to try to help if I can.
I will try to find the info to back up my statements. I did extensive research when I was going to do coilovers and 4 links on my 79.your kinda right.
Everyone should know this.DOM stands for "drawn over mandrel". There are domestic and import variations available...
I am not sure if this applies to all DOM, but its also seamless. There are some nice features of DOM that cannot be found in any other tubing. I know some know this but DOM tubing is capable of flexing more than other tubing and still being able to return to its original shape. this would come in very handy for off roading and rock crawling. Other steels will bend and not return back. I would not buy tubing that is not DOM or is not specified. DOM is also not the standard steel for all traction bars but should be.Absolutely DOM. Is drawn over mandrel. That is the name of the process of how the tube is made.
Sent from my HTC Desire HD A9191 using Tapatalk 2
Well gents ill report back while everyone has the opinion, these have worked out great! I've gotten at least an oil change on these bars. I love them! They work great on the track and under load!!! No binding, noise or anything... They have turned out great!!
Here it towing up around 18k total
Glad that you are happy with your results. Your happiness is all that matters. Just as in anything else in this world. Choices may not always be the best, but if it fits your budget and gets done what you want to achieve along with putting a smile on your face, that's all that matters in the end; not what everyone else thinks.
Tree Trimmer,
What is the best way to figure out what length you need to make the traction bar?
I am getting ready to make some for a 2001 EC/SB with stock suspension and the lift block removed.
I will be using dom tubing and ballistic joints. Should i go with the poly bushing on the frame side and rod end on the axle side or rod end on both?
Thanks
what size are the rear axle tubes on out truck ??
Tree Trimmer,
Thanks
