My intake got in a fight with my mill....
Charles
Aw... I was hoping to see pictures of a manifold that came loose from the vise and got chucked across the shop at mach 8, lol.
MorganY
college station, tx
no not as easy as some would think, I think for this unit we will run a standard egr delete and weld up the egr valve port... haven't quite figured out how to route the coolant...
I welded the egr gas inlet shut on the manifold, and tap'd the coolant outlet hole with a 3/4" NPT and put a plug in it. Works awesome. And used Steve's coolant return hose. Works sweet.
BINGS 03 6.0
WI
So would a 03 intake with crossover removed flow the best between all years? With all being ported, sounds like there's differences in castings around the inlet and egr area. So if your just porting the runners and not the inlet area is one year better than others?
smokinstroker
Texas
I like the idea of leaving coolant flowing through with Steve's coolant re route as we did on Morgan's truck.
Tapping the coolant flow will workout perfect for anyone planning on water cooling their gate in the future
sonic_superduty
waynesfield,Ohio
Well I finally got back to this project! Cut some top plates today just have to punch some holes and tig it up... going to finally get my flow numbers on it sat morning compared to a stock intake! More pics to follow! Then I can hopefully finish the headers
sonic_superduty
waynesfield,Ohio
Well here is the finished part! Fully tig welded, and ready to roll...
Powerstroked162
On Da Juice
Wa. State
Pressure test twice, install once. I found pin holes in three manifolds of mine today. Actually have one more to test but was so discouraged by the third one I had to walk away lol. Looks good though. Let me know if I can help with your coolant and EGR stuff.
