ghohouston
Truck died on me yesterday. Seemed like it ran out of fuel, so I got a push into the station, put $50 worth of diesel in it. Pulled fuel filter, topped off bowl, cranked, pulled filter again and cranked to watch the bowl fill up. Triple checked all fuses, swapped cps with a buddy that is known working. Did have a p340 code, which led me to believe cam sensor. I've swapped batteries from a known good truck too. Checked cps wiring harness all the way up to the hpop res, all looked good. Cranked with icp unplugged, no start. Low pressure oil gauge comes up, while cranking truck builds over 3000 psi icp, hpop res is full, ipr hits 45 percent dc cranking, 15 percent koeo. Replaced ipr pigtail, wait to start light comes on, etc.... I'm not new to the 7.3, hell I used to work on them daily, but I'm stumped. Truck had been sitting for 4-5 years, I bought it and drove it home about 30 miles no problem, and probably put 15 miles on it after that. Like I said, it seemed like it ran out of fuel, I shifted from 1st to 2nd, seemed to bog down, shifted to 3rd and died. Any ideas obs guys?
