ghohouston
That's the plan. I really wish I had the money to convert to e fuel, but can't swing it right now, so another carter pump it is.
Sounds like a plan. The pumps are a pain to do. Most times you have to yank the turbo to do it. But you might not have to.
Believe it or not you can fit a 1/2 ratchet with shallow socket under the pedestal and take the banjo bolt out.
Installed the new carter pump a couple hours ago, and sure enough the old pump was bad. I can't say for sure if the "lifter" if you will, on the fuel pump broke in half, or if I broke it when I pryed up on the pump with a heel bar and broke the part of the pump that sits in the block, but either way, pump wasn't working. Truck started with minal cranking once I put a battery charger on it with the new fuel pump. Thanks again guys
good luck to you. it was a major bish to do without removing the fuel bowl or turbo. my advice is remove the fuel bowl. this truck was parked illegally, and i needed to get it going the quickest possible way, so i decided to not do anything extra.
So you're running stock fuel pump with no bowl? Wtf!?!?
