My night at the track
Sniper32
Stafford, VA
Look like some good runs...but like others have said you should be running faster. I have a basically stock 04 (exhaust, tune, blue spring, and 6.4 banjos) on 6 in with 37s and my first time out I ran a 14.24. With a turbo and injestors you should be hittin 14 flat I would think
fordfreak4life
80HP they are they where giving to me to try im not super happy with them but they where free to test for a shop. nearly stock truck on 37s run low 14s i doubt that there was a nearly stock one on 33s last night and he ran 16 keep in mind the truck is still on the stock fuel system no reg return on air dog or fass just blue spring and 6.4 banjos
Ccsb drw, weighing 8370,ran a 13.94 with gogos race tune, egr delete, studs
Sent from my Milestone X2 using Tapatalk 2
Skinny
British Columbia, Canada
Like I said got a couple things to check fuel pressure exhaust leak and some others was also my first time running it I'm sure my times will get better
Sniper32
Stafford, VA
No reason to get upset man, I simply responded to your doubt. you said a mainly stock ccsb couldnt run low 14s and mine does. As for the fuel psi unless youre dropping below 50 psi I dont think itll change much...and I may be wrong but I dont think an exhaust leak will cause any differnce unless its at the turbo.
Im not trying to be hard on you in anyway, and i am by no means an expert. Ive been down the track less than 10 times, what boost are you launching at? and whats your tire psi? those two things might pick you up a little time, especially in the 60 ft
Sniper32
Stafford, VA
you could prolly launch harder...ive launched between 12 and 15 psi plenty...its all a guesiin game to find out what your truck can handle
Twan
Berthoud, Co
I did a 16.7 with just a 4" exhaust and 35x12.5r16, at 7700 lbs crew long, launched at 18 psi. Your time sems good, seeing as your tire are about 2 times more than most.
If you launch at a higher boost I would think you could drop a few tenths off. Are your shifts quick, or is it hanging up on the 3-5?
Worstenemy453
Fredericksburg, Va
Im not any expert on launching with bigger tires, so take my words here at face value but with 35"s, Hawgdoc's truck launches perfect at around 22-23 lbs of boost. Try gradually upping your boost on launches. Try something around 15-16 and see how that helps.
