My powermax/175 review
faster6.0
TXGLASSMAN
Keller Texas
strokin6L
Springville NY
not all trucks are the same. You can take two trucks with nearly the exactly same setup and both may or may not lay down close HP numbers. There's been many guys running a powermax and 190/100% injectors and not even hit 500hp...close, but didn't make it. However it seems odd that a truck with a powermax and 175's lay down 500hp or slightly over.
windrunner408
dyno numbers look cool on paper, track times prove power...
:whs: In all honesty it really doesn't matter what a piece of paper says your truck will do if mine with less claimed HP leaves you in the dust at the track/street light. Just sayin.
da94broncodude
WJ,UT
thanks jared!
if you guys wanna bicker about the numbers id be glad to post up the dyno sheet, but as i said in my original post idgaf what the numbers are it runs good and im happy with it especially for the money spent. at this point i will poss do an upgraded intake manifold prob gogo etc, a ficm tune and beef the trans a little bit and leave it alone for a while
windrunner408
Well it would be cool to see the dyno sheet and maybe a track time/trap speed, but since you are happy with it, then that is all that matters. Everyone else can go *** a duk.
Fox hunt
Any chance of some vids? I would like to see how much you're smoking, this is the setup Im debating on going with.
