my "workstock" build
6.4strokin
hey fellas excuse my post count it should be around 600 but something happend to my old account anyway guys this is the build im planning on opinions and input are appreciated anyway here it goes
hd pistons
valve springs and pushrods
studs
heads machined
ported intake manifold
6.0 manifolds
73mm and 59mm
cam
elites solid roller lifter set
no limit pipes and intercooler and intake
opinions on a wastegate?
60% nozzles
dragon fire hpfp
anything i missed? I plan on starting it in a month or 2 my first time tearing into a 6.4 but im up for a challenge. Im taking the motor out through the front. Ive got some friends with some cummings that think they can run with me but i think this setup will but me about 820 hp which I think wil be enough to do some damage in workstock around me. Only think im afraid of is the relibabilty of the dragonfire but I cant run duel pumps in workstock. Thanks guys:)
webb06
Seneca, MO
i would coat the pistons too.
are the elite solid lifters released? i didnt think they were out yet...
ive been told those nozzles would be too much fuel but im sure others will disagree with me.
you'll want some kind of low pressure fuel system as well.
6.4strokin
thanks guys im thinking pmfs 4 link kit, forgot to add fuel bowl delete. I do have a airdog 165 but i might get a aeromotive to replace it. Reason why I im going with 60% is because jared rice's 6.4 has been cleaning house in workstock. I saw elite solid lifters on their site so I assume they are out maybe not. Thanks for the input guys!!!!!! This is going to be my winter project so it will take some time thanks again
Super08Duty
College Station, TX
Very solid build, should be an animal. I'd also look at putting a tru track in the rear as well as doing a heavy duty 1 piece driveshaft with loops.
madman1234509
mayfield, ny
I saw Jareds truck at rudys last october, on the dyno and pulling.... Very impressive. Sure it didnt clean upthe smoke on tje dyno like what youd want for a street truck but thats not what its intended purpose was. Id say go for it. Also what about the rumored 76mm in a stock appearing housing?
Also whats the benefit to solid lifters? Anyone ive ever talked to said put new stock back in...
Make sure your suspension is dialed for sled pulling. 4 link, trac bars, good shocks.
one2nine
Altoona, Pa
Rcds truck I think put out 760 on a 72/59 setup with 60s so I'd say 820 might be a little high. I'm just waiting in my injectors and convertor to come back in.
6.4strokin
Jared dynoed 813 I think my goal is with in reach. Jared is getting a built motor for next year also different turbo setup.
Sent from my iPhone using Tapatalk - now Free
farmin powerstroke
athens,IL
I just ran a 811.1 on dp dyno last week with 30% and 75 59. With 60% and a dragon fire you will have to refuel it some.
Sent from my iPhone using Tapatalk 2
one2nine
Altoona, Pa
Jared may have dynoed over 800 but their 72mm batmo setup with 60s put down 760. I'm going to see how I like this new setup for a while but the new elite 76mm is tempting.
