Y2KPowerstroke
- Joined
- Jul 7, 2016
- Messages
- 2
- Reaction score
- 0
I want to get a new turbo for my 2000 7.3 f250, any suggestions?
Sent from my SM-G920V using Tapatalk
agreed!!You can go al the way back to TDS days. There was a guy there that always asked "What's a good turbo?".
There are a lot of good answers to this question.
Do you want simple drop in swap. Easy answer GTP38R. It is a great turbo from stock injectors, and will handle up to some decent injectors, like 238\80's, or mini me's from DI.
if you don't mind swapping everything from the block up and everything after the exhaust manifolds, the question has a million or so answers.
whats the price on that kc38r? and specs that show its better? turbine side must be different if it is a big difference id think.No question the KC38R is better charger than the Garrett 38R as far as drop in factory replacements. Better warranty, billet wheel, and comes with the high flow outlet flange installed.
Stock to 180/30 injector run the .84 housing, anything bigger, run the 1.0 housing.
ahhh 10-4.. basically a van turbine. should make a good turbo..$1490 shipped
66/93 compressor
76/70 turbine
Boost/drive pressures are much closer to each other compared to the Garret on my 250's. I've got 450/400's now, but I'm quite a ways from being dialed in on tuning. Mainly just no time to mess with it.
as in two smaller turbos of equal size?Might want to try a twin setup with that much fuel
Did anyone ever do a legitimate twin(not compound) setup on a 7.3 that actually seemed like it was a good setup?....not trying to derail.
