Need a new turbo
hucorey
Defiance, Ohio
ahhh 10-4.. basically a van turbine. should make a good turbo..
Yup, not sure if Charlie tweeked the turbine wheel design a bit or not, but the inducer/exducer sizes are the same I believe.
It pairs up with 230cc /100 hybrids quite well.
Did anyone ever do a legitimate twin(not compound) setup on a 7.3 that actually seemed like it was a good setup?....not trying to derail.
it doesnt work. By the time you keep the turbos small enough to light, there is nowhere near the air on top to give enough peak power to justify the labour and expense.
ja_cain
That's an easy fix, just run compounds on each bank. Lol!
someone had a pulling truck with one off each bank.. i think ran 400s and looked to work well..
Never street drivable...
efhardwork
Is your truck stock? I also pull a fifth wheel and I'm looking to replace my Turbo. Thanks for your help
