Need advice asap
ghohouston
Lewisville,Texas
Pulled dash on a 6.4 yesterday to replace heater core. Truck started and ran fine before. Got all back together, and the ignition will not do anything, moves about 1/4 turn. I have quadruple checked all connectors, and the grounds in the passenger kick panel. The cluster does not come on or anything. Checked all fuses as well. This guy needs his truck up and running asap. Thanks in advance
co04cobra
WV
Try switching the 2 bigger plugs under column itself. IIRC those 2 can interchange.
ghohouston
Lewisville,Texas
I considered that, but didn't want to do so and blow a bunch of fuses, but at this point i guess it's worth a shot. What gets me is the ignition not turning its full travel. Unless on the 6.4 it has some sort of electric lock...
ithumpwheniwalk
BC Canada
Hate to be that guy and ask, but did you wiggle the steering wheel either way while turning the key? The wheel lock hasn't engaged? Dunno, I'm not a newer truck guy but I've busted more than 1 ignition lock cylinder that way. I know I know, I'm a dumbass :doh:
JMart
DFW
I used to be a locksmith, you would be amazed at the amount of times this fixed a "frozen" ignition cylinder.
ghohouston
Lewisville,Texas
The owner did that first, and I am wondering now if he did break it. He is a big dude and was trying to turn the wheel while on the key. The wheel never locked. He went over 1/2 turn each way.
DEEZUZ
NO PUKESTERS
NWI
Pull the ignition switch, not the tumbler out and manually move they lever
