Ok first I will say I have a 2000 7.3 with 185,000 miles truck is blowing blue smoke that smells just like diesel, at idle only just changed injector orings and glowplugs and the truck is still smoking. It don't look like I have any oil in fuel but it uses a little bit of oil. The truck runs and starts normal I hooked the scanner to it and the 2 codes I'm getting Is a exhaust pressure sensor and a PCM code. Every now and then I can hear I knock not sure where it's coming from. And I will say when I pull oil filler cap off it blows a little white smoke out. Any help would be awsome thanks I will post pics or videos just don't know how to
